Engine check light flash
Hey,
I have jagaur s type 2006 ,3.0l v6
I had my engine check light on while driving and before engine strated
So I have reset the computer , by disconnecting the battery , and there you go check engine light was gone while turning on the engine and while driving , it was only flashing while turning the switch , but while engine turned on no lights was flashing and everything was fine ,
So I was driving the car a couple of dayes everything was fine , now , today I started the car and engine started to go back and forth like kicking very weird feeling , so I immediately turned off the engine , and second time I tried to start it , it just won't start , any idiea whats going on ?
Received 2,632 Likes
The following 2 users liked this post by NBCat:
Don B (08-12-2019),
motorcarman (08-11-2019)
Received 12,946 Likes
Hi Simon99,
Welcome to the Jaguar Forums! It's great to have you with us.
Yes, a scan tool can read the diagnostic trouble codes by turning the key to position II (ON/RUN) without starting the engine.
Probably the most common cause of the flashing Check Engine Light (CEL) is excessive engine misfires that allow unburned fuel into the exhaust which can lead to rapid destruction of the catalytic converters.
Please keep us informed.
Cheers,
Don
Cheers,
Don
Radio Codes
Also, it's a good idea to put a towel or such over the trunk latch to prevent the lid from latching, just in case the lock barrel is seized and won't open with your key.
Cheers,
Don
kr98664 (08-20-2019)
Yes , I have connected it but no codes would appear even tough check engine light is flashing .
Simon, sure looks like your IMT o-rings are leaking. A very common issue on our V6 engines. When the valves leak they can cause a vacuum leak too.
I am attaching a link that will describe how to R&R. Within the link is another link on a simple way to check if they are leaking.
https://www.jaguarforums.com/forum/s...ics-faq-32135/
Don B (08-20-2019)
The OP disconnected the battery on the car and left it isolated for a good period of time. This looks like a "hard reset" to me; his stored error codes and fuel trim data will have vanished, making the process of running diagnostics difficult, at best.
In terms of the oil leak, it may well be coming from the front main (crankshaft) or pan seals. Taking the bottom engine cover off and having a look-see would e a good idea, as opposed to jumping to conclusions...
I really can't do that since it would be pricy to take the car to the garage since it wan't start I can't drive their ,
So you don't think the problem in the spark plugs , since it was indeed driving clean before it went misfiring on the spot without even shifting gears .
"Disconnecting the battery (a hard reset) only clears adaptations held in volatile memory such as fuel trims. It does not clear stored DTC's triggering the MIL. The only way to do this is to fix the cause
Graham"
My guess is that the IMT o-ring is leaking as with the spark plug seals allowing oil to gather around the spark plug in the spark plug wells, very common on these V6 engines.
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/3-0-oil-pan-removal-w-pics-faq-52987/
Here is another thread worth reading too:
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/2003-3-0-90k-maintenance-49309/
