engine code p1383?!
Thank u . um I checked it and I'm confused on what exactly is wrong and I called jaguar and they didn't give me an answer they pretty much said they weren't sure unlessnibbring it in.... I just want to be prepared for damage so I know to say I give up or fix.... I'm $5000 in on a $4500,car
Don't know why the search result page does not show correctly.
GoTo:
(click) SEARCH
(click) Advanced Search
in "Search by Keyword" type P1383
in "Search in Forum"type S Type
(click) Search Now
Two pages of results will appear.
GoTo:
(click) SEARCH
(click) Search Now
hilaryv215 (02-02-2015)
Lol well jagv8 I'm very good girl but I am polish so help is needed
Could you please help me.
I can give u a quickie rundown
I am about due for oil change I do have a leak and when I checked my oils empty practically now.
That being said for the first time with engine light and code p1383 it went a little over on the c/h temp thingy in my dash
Now my understanding.... Please tell me if I'm wrong.
I can engine flush and complete oil change and have a chance?
All above posts make sense.
I came up with 2 pages of results for "P1383" yesterday and this morning. I do not know why my link did not goto the result page, sorry. I did show you how to "search" though instead.
Mainly due to lack of oil change maintenance. Do this: purchase engine flush - run engine (from cold) at idle for about 20 to 25 mins, drain oil.
Put in conventional cheapest oil you can find (5w20 viscosity) and I mean cheap like auto big box branded oil like advance cause your gonna change it after 1,000 miles.
Here's the trick - sub 1qt of oil w/ Mercon 5 transmission fluid. Trans fluid is highly detergent and will penetrate and clean the small oil passages of the VVT solenoids.
It takes about at least a few hundred miles of normal driving.
The above method is proven.
Also there is a TSB for VVT's for the 3.0 engine that is remedied by reprogramming.
The following 2 users liked this post by abonano:
hilaryv215 (02-04-2015),
Jumpin' Jag Flash (02-04-2015)
So I readeverything i could on here took abonanos advice and took to mechanic had a engine flush and oil change than changed my other fluids out myself and light is still on but only drove 20 miles but no lag in driving and not over heating so thank you
I did take pics of how to find the latch if there's anywhere to post em in case any other pollocks can't figure it out
Please read up on the forum - lots of info and $80 for an engine flush? Again, I was trying to offer you a proven solution that has helped many fellow members in the past. Unfortunately, you threw $160++ at a problem that may not yield a suitable solution.
You need to get a reflash of the PCM via a dealer level dial agnostic machine if it was not done previously. jaguar can tell you if your vehicle has been serviced for the TSB.
