engine light came on after changing spark plugs
David you are getting really close to adding your vehicle in your signature. Look for "USER CP" button top left, click on "edit signature" then add your car detaills "click save" and viola you are there!
As far as your plugs just keep the autolite XPs in there. They are great plugs and will perform nicely for you. Why go through the headaches of changing all 6 again.
That said if you are still throwing misfire codes, you may be in need of coils. I will not tell you to purchase through www.rockauto.com but they are the cheapest out here for the 2003 and up 6 bangers (part # UF435). NOTE: make sure you order the right ones, there are two different styles listed! You have the 4 wire and NOT the 2 wire coils that are less expensive.
Received 6,321 Likes
xjrjag
10-27-2021 11:48 PM
X_Type_South_Africa
12-09-2015 05:37 PM
