engine lights on code p0171 p01714 p0465
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
engine lights on code p0171 p0174 p0465 2003 str great car lots of problems
car lag's under acceleration and pulls back over 2000rpm
spend 2000, 8 months ago on 2 new fuel pumps at jag dealer says codes on have nothing to do with the problem
thanks
thanks
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
i love the str i would also like to do some upgrades but im scared to touch anything untill this issue is fixed when i push past 2000 rpm sometime it pulls back and makes a grinding noise some people say its a vapor leak should i do a smoke test new plughs NEED HELP
thanks great forum love the posts
You need to understand codes only say what the symptoms are not the cause 1 code can be caused many different things, take the first 2 codes, running lean both banks, you now have to work out what's causing it to run kean on both banks, running lean means more air than fuel in the mix, start with none cost diagnosis first, do es jagv8 suggests and look for airleaks first.
Isoruku
06-19-2020 12:54 PM
X_Type_South_Africa
12-09-2015 05:37 PM
