Engine management light
hi, I have a 2004 2.5 v6 s type, the other day the engine management light came on while driving, I checked the self diagnostic test which gave me these readings
Dtc 9689
Inside rearview mirror motor #2 (horizontal) circuit open
9246
Dim panel potentiometer switch circuit failure (airbag or rear view mirror circuits)
E511
CAN - DATA MIS-MATCH (RECEIVED DATA DOES NOT MATCH EXPECTED)
A879
Tilt down switch circuit open (rear view mirror)
E518
Climate control fault flagged
D900
CAN COMMUNICATION BUS FAULT - RECEIVE ERROR
Dtc 9689
9246
E511
A879
E518
D900
They're not current are they?
Any that are will be shown by a normal OBD tool (such as the one you used).
The ETM ones can be and usually are many years out of date. Pity they exist.
No offence but the pics posted just look like aimless messing around. What were they intended to prove or show?
Yes can you get the codes read at Autozone?
Not sure what to make of all those Snap-On scanner shots?
After you get them read have them erase everything so we can see what codes come back before you start doing anything. Always want to see the codes repeat so we are sure they are real.
trevor112468
04-07-2010 03:39 AM
