Engine runs rough on start up
2005 S-type R. Starting happening last night, I started the car and it ran really rough, rpms jumped around and car felt like it was going to shut off. I revved it a few times and eventually it stabilized and then I was able to drive it.
No CEL light, however I checked pending codes and got P0300 and P1316 the first time and when I turned the car off and re-ran the pending codes I got P0300, P0301, P0302, P0303, P0304, P0305 and P1316.
Any ideas on what the issue may be?
I've got a similar problem, and will be curious to hear what you find.
My problem is more of a lumpy/wobbly idle at 1200-1300 rpm, not dramatically fluctating rpms. It evens out on its own after approx 30-45 seconds to a fairly smooth 800 rpm idle.
I'm a rank amateur, but speculate that is when it goes into closed loop as O2 sensors reach temp and trim kicks in and can add fuel. I did noticed fuel trims max out both banks +25 at idle which I had not seen before. I need to recheck at 2,500 rpm.
Quantico (12-23-2015)
Ok so visited my indy mechanic. Confirmed that there is a vacuum leak on the left side (not sure just where yet). He didn't have time to do the smoke test, however that is the next step next week. Didn't seem like it was coming from a hose as he checked them all. Any other common areas for vacuum leaks on these engines?
tat2ist
27
05-20-2022 09:41 AM
Winston Gilbert
02-11-2016 02:32 PM
Portfoliolio
11-29-2015 09:58 AM
rhino0907
11-14-2015 05:32 AM
zee oh sex
158
06-16-2011 12:30 PM
