Engine Shut Down while driving
Received 2,263 Likes
I over estimated the oil consumption.. just checked it again it is two qts extra, so it needed three only.. i know it still is low oil. None of the lights came on at the time of the incident. I just checked the fuses and battery and they are all fine. Could this be a fuel pump problem because the guy whom i bought it from said that he had to replace fuel pump about year and half ago. If it's a spark plug related problem, then shouldn't it make that continuous clack noise that just won't wanna start. but in this case it just one clack and done. I don't guys, i really don't wanna replace the engine or at least i hope i won't have to.. thanks again for all your help, really appreciate it.
My amateur advise... It probably is something electrical, a short or something. Take Mafioso's advise and test it to see if it is seized. The manual method would be my choice. With the plugs out to make it easier to turn.. If the motor turns, then it is off to trace and test all the electrical circuits (starter, ignition, etc). At that point my amateur butt would be off to make an appointment with a mechanic.
Oh, yea, didn't the earlier 4.0 have timing chain issues.... Hmmmmm????????
Last edited by JOsworth; 08-24-2010 at 04:16 PM. Reason: Thought of something else...
#30
So, I took the car to a mechanic and he did exactly what Mafiasso told me. He tried to turn it manually, but Engine did not turn at all. He is saying that engine is locked. I am not sure what that means. I am thinking timing chain may be? and if it is that, then is the engine gone or is there a possibility of fixing it?
#32
mine did the same thing but i have no breaks at all either. Dont understand it i was only 2 quarts low
#33
#34
#35
Hi,
I own 2001 Jaguar s-type v8 and yesterday when I was driving on highway, the engine just shut down with no warnings. I, first, thought it was a battery problem, but my friends and I tried jumping the car, but it would not do anything. When I turn the ignition key, the engine make a click sound once and that's it. It sounds like it locked or something like that. Then I remembered that my engine light came on day before that, so I checked my oil and it was a bit low. So I put more oil in and tried again, but it still make that click noise once and thats it. My radio and everything else runs fine, so it might not be battery problem. But I am not sure, so has anybody gone through this before or can you suggest something that can help me out? Thanks you very much and any help appreciated.
#36
The OP reported that the per a professional mechanic, the engine was locked up and would not rotate when a breaker bar was used on the crankshaft bolt. My guess is that the timing chain let go from non-updated original tensioners and locked things up...
BrentGardner
28
04-26-2024 03:08 AM
