Engine Swap, rough idle?
So long story short, I got a 2001 Jaguar S Type 4.0 v8. Couple of days ago I finished swapping engines. Then new engine that I put there is from a 2000 Jaguar S Type, engine and the tranny both. On start I got a rough idle, vibration in the car. After looking around I found out that the car is operating on 5 cylinders. There is a spark, coils are good, and there is compression. Also transmission works rough, quick gear change with a slight jerk. My question to you is, could all of this be caused by an ECU? I haven't replaced those yet , so I was wondering if that could be it before I start pulling everything out. Just to clearify the other engine was pulled from a car, so I have the actual ecu that was on the 2000 jag. Any help would be welcome. Thanks.
Did swap coils, no change. Wiring is good so are the injectors. You dont think it could be the ecu? I didnt swap them i left the old one in.
