Engine Temperature High
Hi everyone,
I have a little problem with my 2002 S-type sport. Recently while driving it, I started randomly getting a warning message that says 'engine temperature high' in red, and my tachometer on the left will go all the way over into the red. But it only stays this way for about 60 seoconds, then the message goes away and the engine temperature tachometer goes back to normal, right in the middle. It is pretty random. Any ideas what could cause this? Thanks!
I suspect you mean "gauge" (or needle) not tachometer (which is the rev counter).
If you're reasonably lucky, it could be a failing temperature sensor (or its wiring). But it's critical to the PCM so if you don't DIY find a reliable shop to fix it now.
It's worth checking your coolant level (but I can't see it being that).
If you're unlucky... er, hope you're not!
It'll help if you can report anything common to the times it occurs so start mentally noting anything you can - as well as how often. A shop will need data.
rachelstr
09-03-2015 12:59 PM
