engine trouble
Guest
Posts: n/a
engine trouble
I own a 2000 s-type 3.0. Just bought it. When the engine is cold, it runs great. After about 20 to 25 miles it starts missing. Gets worse the hotter the engine gets. A code did come up for 6 cylinder, and new spark plugs removed the code. Now no codes are coming up, and the motor is still doing it. Can anybody help? Thanks
RE: engine trouble
Yeah, those are coil- on- plug setups, and it may be a bad coil. Let's hope the plug wasn't fouled by an internal fault, which a compression test could shed some light on.
Before things get complicated, you may want to try cleaning the Mass Airflow Sensor with somr CRC brand MAF spray cleaner.
Wait awhile for some additional advie, FactoryJagTech, jag_genius and ibjags are all very knowledgeable on your model and generous with their insight.
Guest
Posts: n/a
RE: engine trouble
Wow, thanks alot for all the help. When I first got the car a code was coming up that said 6 cylinder, so that will suggestion definetly will be tried. Am going to replace the coil packs this week end and see if that will help. Once again, thanks for help, and I will let you know how it goes.
Guest
Posts: n/a
RE: engine trouble
Hi again, found a vacuum leak and fixed it. Took the car for about a 50 mile dirve and it "bucked" 4 times during the drive, but absolutely nothing like it was before. Think I will drive it for a little bit and see if it get worse. Car has not been driven for about 4 months, maybe just some new gas??? Oh yeah, what would changing 5 coil pack with 6 actually do? Thanks for your help everyone.
Guest
Posts: n/a
Wolfy
05-28-2024 08:06 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
