EPB "Groaning Noise"
My epb makes a sort of groaning noise when I pull the key out of the ignition.
I just lubed the cables, but the noise is still present, though not quite as loud as before.
Could the epb actuator motor be on its last legs?
Received 2,263 Likes
abonano (11-18-2016)
The sound is more like someone saying "Hhmmmmm!",with a raised eyebrow and beard stroking lol...although more mechanical sounding!( My 2 1/2 year old son imitates it when he's in the car!)
Well JagV8, if you've had the noise for 7 years, I won't worry about it either.
I was paranoid of being stranded so I used to hold the epb paddle down while pulling the key out of the ignition, but grew tired of doing that every time.
I thought it was ridiculous to have that feature on an automatic, that everytime you park, the pb is applied. In other cars, I would only apply it on steep incline/ declines to relieve the transmission parking pawl. I know it can be disabled via IDS.
Mikey thanks for the advice, but like Jag said where its located, I think I'd rather replace the unit at that point ( although I've never priced one, I'd probably re think that one!)
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
When the EPB fails, you will most likely hear an annoying, rapid, high pitched beep coming from the dash when you start the car and when you shut it off. Lots of chatter on the forum about that beep; someone recently posted a video of it.
It's worth reading up on EPB failure now if you think yours is on its way out. Thankfully, EPB replacement parts aren't that expensive.
Jimmy 68 (11-22-2016)
