EPB Remove replace pre sale
SO, after some joyus years with the STR Im going t move into something else.
the singular issue with the STR is a non working EPB. What I cant find is a guide to remove/replace the motor. I recall hearing it was above the back axle and hence a PITA
Anyone tackled this?? Im hoping to determine if I want to undertake or have it done by a shop prior to me putting it up for sale.
I mean I did the knock sensors and under SC pipe on my own which requires removing half the engine. But I don't have a lift if that's required for this task..
Thanks in advance
Thanks in advance
Received 2,263 Likes
Yes, fully trouble shot , save from taking it to jaguar to diagnose
If the electric motor needs replaced then yes it's above the rear diff. You need to remove a couple of bolts and drop the pumpkin down a bit to get at the EPB. Just make sure that's your problem and not the cables or the calipers.
See attached TSB's for more info.
This one is pretty good with pictures. No one has come up with the repair for the gears and the only option is remove and replace.
https://www.jaguarforums.com/forum/s...r-apart-53753/
https://www.jaguarforums.com/forum/s...storage-53003/
Received 6,320 Likes
Search for posts by phd12volt
Robert1968
06-24-2017 11:16 AM
CaneCounsel007
12-29-2015 08:35 AM
