error code p0305 and others
My car started running rough (assume running on 5 cylinders). Moment later car went into restricted performance mode read codes and got
p0305,p1313,p1111.
I assumed the cause was 0305 beacuse that is for misfire cylinder 5
changed plug no change
changed coil pack this am no change.
any ideas?
Are the other codes just coincidence or possibly problematica as well. Car has run perfect for the 2 years that I have owned it
p0305,p1313,p1111.
any ideas?
Received 6,330 Likes
If you have done this job, is there anything I can easily break doing this that I should watch out for. I have the alldata steps for removing intake, but it always looks easier than it really is. Come to think of it, this does not really look that easy.
http://ww2.justanswer.com/uploads/cr...per_intake.pdf
That seems a lot harder than the rather similar earlier car:
Jaguar HELP!: Intake manifold in a 2002 S-type 3.0L
Auto Zone and the like carry FelPro aftermarket lower intake and plenum gaskets (seals) needed. IIRC both sets should be around $60.00, is it worth the risk or gamble???
I have it down to 15 minutes to remove the intake system. I have only done it 3 times in 4 years. Just follow alldata and you can't go wrong. Just take caution removing the quick connect brake booster vacuum line on the back of the intake (words of advice)
The fuel pressure regulator is just a slide on/off rubber elbow (blueish circle in pic)
The quick connect brake booster (yellow circle) push the booster line into the manifold gently pry the black collar back (away from manifold ever so slightly) pull brake booster line out. To install just push brake booster line back in.
Found another angle of the brake booster line.
You need the slightly pry the black plastic ring away from the brass cylinder (which is pressed into the manifold itself). Its works like an air compressor quick connect.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/21948d1343770464-error-code-p0305-others-rear-intake-vacuum-connections.jpg)
edit: If you cannot get the brake vacuum line out of the quick connect, you can gently move the manifold with vac line (still connected to the manifold) off to the side for enough room to do what has to be done. Just be carefull that you don't crack the vac line!
