Error code P0504, U0103, U0128
Good Morning - I have a 2007 S-Type 4.2 that got hit on the passenger side-low speed hit in a parking lot. Had the damage fixed and I am now getting these errors; 504-brake switch A Brake switch B Brake correlation; 103- lost comm with gear shift knob; 128-lost comm with park brake control module. Is there a relay or fuse involved with this? The car seems to drive just fine. Any help would with this would be great. Thanks
Received 13,379 Likes
Hi flash88,
Regarding the P0504 code, try the procedure in this document:
X350 Brake Correlation Adjustment
The U-prefix codes have to do with network communications problems. You might review the CAN info near the end of the Electrical Guide:
S-Type Electrical Guide 2006-on
Out of curiosity, what scanner was used to retrieve these codes?
Cheers,
Don
Cheers,
Don
EssOess (03-11-2017)
