Eureka! Found the unfindable!! Lower Front ball joint 05 jaguar s type
So did some digging and was able to source the front Lower balljoints for the 05 jaguar s type.......I got myself 4 sets just in case......so if anybody wants a set they are 120 shipped to you CONUS. see attached picture.....
PS I am only willing to separate with 2 sets need to keep one in reserve!
The following 2 users liked this post by tbird6:
GT42R (11-26-2013),
Jumpin' Jag Flash (12-27-2014)
The following 3 users liked this post by Lt0302:
Anybody know if these will fit too? New Lincoln LS 16mm Lower Ball Joints 2 02 06 OE Spec | eBay
The seller lists them as compatible with the S-Type as well as the LS
I realise the whole arm is generally available, as with all manufacturers these days it seems, but wondered if the balljoint was hard to find in the UK as it seems to be in the US.
I'm not aware that I need one, but would like to know where I can source one, should I need to.
Hi,
I do have the lower control arm new on the left front side that I had got for my Jaguar S-Type '02. The part # XR851825. I think its the same for the 03 model as well. PM me if you're interested. I could ship it to you or you could pick it up if you're local to South FL
What's the point if only you can get them??
Totally useless information. There was never any question that ball joints exist and can be pressed in. That's what the factory does.
No the Lincoln LS and the S Type changed with the 2003 Lincoln keeping the old suspension while Jaguar updated the S Type to a newer style front suspension.
So the Lincoln LS lower ball joints are only for the 2000-2002 S Type. And don't forget the running change from 14mm to 16mm either. Also note that EBay listing has the very common error of listing the 2003 S Type. That is wrong.
If you read my first post carefully you will NOTICE that I am offering to share 2 sets from the 4 I got....they were shipped from EU....I am not making any money on them just passing on to fellow jaguar owners!
Lastly not my fault there is no aftermarket support.....however I was able to score some!
When I was stationed in Germany I was part of a car club, thus made a lot of friends.....I posted my ball joint dilema to the club and someone was able to source them from the supplier. Sadly these are not freely available on the market!
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I just found 16mm lower balljoints are available in the ROCKAUTO
catalog from various manufacturers!!!!!!!! I'd like conformation from
my forum friends before I consider buying. I found them using my
04 STR as a search.
Thanks!!!!!
Link= 2004 JAGUAR S-TYPE Ball Joint
04 STR as a search.
Thanks!!!!!
So far the answer is no. I think the listing is in error because you can look at the 2002 S Type and they have the same part number listed for the lower ball joint and we know they are different.
I think all the parts places get confused because the Lincoln LS does use that 16mm ball joint up until the end in 2006 when production stopped.
We do have member Lt0302 that was able to find them but he has no part number and it looks like they are still NOT available for the 2003 and up S Types.
The 14mm .VS. 16mm is for the Gen I ball joints and was a running change sometime in the 2001 year. It goes by VIN so that must be checked to be sure.
We are still looking for the 2003 and up S-Type lower ball joint separately.
Jumpin' Jag Flash (03-19-2015)
