Exhaust/Fuel Smell
Exhaust/Fuel Smell
I have a 2001 STR that is bone stock. It has about 90k miles on it. The other day, I was driving along (semi aggressively on the street) and I noticed a strong smell....sorta like gas or exhaust. Almost like a carb car that is running to rich. Then, the car started to hesitate. A message showed on the dash that said "restricted performance."
I limped the car home and started it again in the morning. It idled extremely rough. So, I had it flatbedded to my mechanic. He plugged it into the machine and their were no fault codes. He started it and it ran rough for about 10 minutes and then was fine. He drove it for a few days and said there were no issues.
So, I picked it up and started to drive it. Although it drives fine, I still smell a fuel/exhaust smell. It isn't as strong as before, but it is still there as my daughter noticed it and thought I had farted in the car.
So, back it went to the mechanic and he couldn't find anything wrong. He even put it on the smog machine and said that it ran so clean you could start it in your bedroom.
This issue is baffling to me. Anyone else run across this problem?
Thanks.
Paul
Thanks.
Paul
Received 2,643 Likes
Did you notice the smell after adding or topping up the fuel? It is entirely possible the problem was some poor quality fuel.
I guess you need to clarify: are you describing a raw fuel odour or is it more of a 'rotten eggs' type smell that your daughter noticed? I'm always amazed how children will often say what the adults are thinking!
NBCat
NBCat
S-type 2.7 as it got colder I can hear a hum or wind sound alongside engine noise then smell of diesel. I can isolate with internal air only button. I seems to have started when the temp dropped to below zero. I have had the particulate filter removed. I do use shell vitro and an occasional additive. Any ideas folks?
