Exhaust Leak
Exhaust Leak
So...is there some kind of dark magic involved in conjuring up an exhaust flange gasket? I found the exhaust leak, passenger side, between manifold and exhaust pipe. People are standing on street corners selling exhaust manifold gaskets for my car but the flange gasket appears to be a unicorn. Is it the same gasket for other models that have the 4.2? Any suggestions where to source one? I'm hoping this exhaust leak accounts for some of the quirky live data I've been seeing. O2 sensor jumping around, ect...
joycesjag (02-06-2024)
Received 2,637 Likes
With all the random DTCs you're finding stored, the first place to begin sorting things out is by checking the available battery voltage. Many random instrument cluster warnings, DTCs, and other electrical 'gremlins' are caused by insufficient available voltage.
With the ignition in the off position for at least thirty minutes, use a voltmeter to determine the available voltage. There should be a minimum of 12.6 volts indicated on the voltmeter. If there is less than 12.6 volts showing, charge the battery for five hours at 2 to 5 amps and retest. If voltage is still below 12.6 volts, the battery is suspect.
Steve W
XJ40 ( XJ81 )
09-16-2011 02:20 AM
