Exhaust tips! Who has what? MagnaFlow, Borla etc PICS please
The only thing left on my car I really want to do is exhaust tips. What fo you guys have?? I'm really hoping to see a pic of double wall magnaflos on a car. What length tip do I need, inlet and outlet diameter, I believe inlet is 2.25 on a 03 s type 4.2, and I''m also thinkin 4" outlet would be cool. Lets get some feedback and pics!! thanks!
this is what I was thinkin, is this too big?
Magnaflow Stainless Steel 2.25 inch Exhaust Tip is designed to reduce exhaust gas pressure and enhances the performance of the exhaust system. It is manufactured from high strength stainless steel and come in mirror-like finish. This exhaust tip feature a inch tip. It is corrosion resistant and is backed by lifetime warranty.
Dress up your ride with one of MagnaFlows stainless steel tips.
Dimensions: 14.00L x 6.00W x 4.63H in.
- Backed by lifetime warranty
- Corrosion resistant
- Easy to install
- Manufactured from high strength stainless steel
- Reduces exhaust gas pressure and enhances the performance of the exhaust system
- 2.25 in. I.D. Inlet
- 4 in. Round
- 8.25 in. Long
- Rolled Edge
- Angle Cut
- Double Wall
- Polished
Magnaflow exhaust tips
I don't think you want 4" exhaust tips. You don't want your Jag to look like a teenager's rice-burner do you ? I suggest you stick with no larger
than 2.5", like mine, except try to get as short as possible so it remains tasteful; not too much coffee can type. Magnaflow part # 35190
Good Luck.
The following 3 users liked this post by jag79:
I'm really not seeing this rice burner look you guys are refering too. Jag79 just posted the pic with the 4" on his and I think they look perfect. Am I just confused on what is rice burner now-a-days. With how jag79 has them mounted they almost look like they are stock. This is what I think of when I think of rice burner exhaust.
The following 2 users liked this post by ChrisSTR:
Dimension247 (06-19-2011),
jag79 (04-24-2011)
Whoever made the ethnic comments is a retard btw...
(no offense to retards intended).
Take care,
George
The following 2 users liked this post by androulakis:
jag79 (04-24-2011)
jag79 (04-24-2011)
Thanks to Jag79 my 03 STR runs the exact same Magnaflow 4" s/s rolled edge exhaust tip. IMO the best tip. Again IMO, don't let them stick out too far. I was runnin Mina's twin pipe exhaust tips (they whistle "Like a whistle" under heavy acceleration). The magnaflow 4" do the right trick. I had them set so they barely protrude from the rear bumper valence (like stock). They properly fill (not over-do) the exhaust tip cut out, and look both mean and tastefully appointed.
jag79 (04-24-2011)
An exhaust tip is designed to reduce exhaust gas pressure?? Huh? Isn't a tip just a cosmetic boob job? Wouldn't a Magnaflow muffler do a much better job? I want to change out my mufflers to a MagnaFlow but I'm not really convinced of doing so yet... but an exhaust tip?? Are you serious?
Great info so far, I think I really like the 4" to go with the look of my car. I dont have r, just the 4.2 Sport. Not really looking for sound or performance so I don't need the exhaust or mufflers. Just want a better looking rear end. I also like the Borla 20156, but I'm not too sure if 2.5" inlet is too big for a non R
Agreed, how does a tip make any sort of performance difference?
