failsafe engine mode
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Hi
Can anybody help i was driveing my jaguar s type 3.0 1999.
down the m2 tonight and all of a sudden the failsafe engine mode came on then went off then came on with an orange light with it then it went off then came on but with a red light by it then can slowed right down i turned it off then on again then the car run fine until it all happen again.as anybody got any idears.
Received 6,307 Likes
Welcome to the forum Steve,
You will have to get the codes checked to see what triggered the failsafe mode and post the results before anyone can help.
In the meantime you might want to post in the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Hi Steve. Did you happen to drive in a hard rain? The "S" electrical system is susceptible to intrusion of moisture. Check the state of battery charge. Even with a weak cell, the batttery will start the motor but not dliver adequate power for the electronics. Check the above then report back.
It can only flag codes if certain things are the case (see codes PDF in stickies / JTIS and read up on OBD if you want the quite complicated details).
Things to do: check battery / replace if oldish, check for damp (boot/trunk, coils, PCM maybe), check LTFTs (long term fuel trims) at idle & 2500rpm in Park because they'll show if you have an air leak. Report back in due course if stuck.
scottatl
09-04-2015 08:08 PM
