fault codes
pampurd,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center section to S-Type section. This is the place for questions about your model.
Here's the link to the JTIS download in S-Type FAQ's:
https://www.jaguarforums.com/forum/s...archive-66031/
The DTC's (Diagnostic Trouble Codes) PDF is in JTIS.
pampurd (07-10-2013)
If you only need the fault code list without having to install JTIS, here it is:
S_TYPE_2003_MY_DTC.pdf
If you already have JTIS installed, click on the DTC button (circled in red) and then select Model (arrowed green) and Year (arrowed purple) for the appropriate listing.
philwarner
25
06-26-2021 05:43 AM
