Few questions regarding aftermarket exhausts and resonator delete
I'm curious whether there's a significant difference between a standard exhaust and the one without centre resonator. I read threads about XKR, but they have more resonators so the difference in case of STR might be bigger.
Also, I'm wondering whether silencers from Miltek or Mina are chamber or straight through. I have custom made straight through silencers on the car and although the sound is nicer than stock, I would like to hear higher pitched tones as well. As I understand, I would need to get something like Flowmasters Delta 40/50 to achieve such effect. Or maybe, it'd be enough to just delete the centre resonator and eg. put x-pipe in its place.
PaleRider (06-05-2011)
michel, My STR exhaust is basically stock except for Magnaflow mufflers. I removed the resonators and replaced with an H-pipe...nice sounds but too loud for my highway cruising tastes so back on with the resonators. A Magnaflow X-pipe just after the cats is going in. I'm curious of its benefits and sound. I may delete the resonators if acceptable sound level with Magnaflow X-pipe. 2 1/2" pipe from cats to mufflers go on next, followed by crank and s/c pulleys, and ECU dyno tune. Hope this helped and please let us know what you experience too.
I am currently running custom build mufflers and think of replacing resonator with either standard Magnaflow x-pipe or dual in/out Magnaflow muffler with Tru-x core. Don't want it to be too boomy if I go for the unresonated one.
Another question... I have never heard about lower airbox and throttle baffle removal... Where is it located, what does that do?
I might have another reason to tinker with my car during the weekend
michal, remove the airfilter...on the lower left (radiator side) of the airbox you will see a flap that is actuated to open while under full open throttle. You can remove it by unscrewing the screws holding it in place. This allows more air to enter the airbox giving crisper throttle response with just a little more air intake noise.
Naso--Lituratus (02-28-2015)
Thanks 390hpstr, I don't know if I'd personally enjoy the "resonator delete" drone. I'm placing in the Magnaflow x-pipe but may replace stock resonator with separate higher flow aftermarket resonators to minimize drone. The new Jags use 2 1/2" exhaust pipe with separate tube style resonators. I'm wondering if they also come with an x-pipe?
and does drone between 1500 and 2000 rpm but the noise is addictive
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
http://i783.photobucket.com/albums/y...T/Img_0398.jpg
![](http://i783.photobucket.com/albums/yy112/STYPERNUT/Img_0401.jpg)
