Few S-Type questions (Newbie)
Received 6,327 Likes
In the HVAC guide, there’s a link to tips by Gus for replacement. Notch the bracket as he has suggested to make installation much easier.
In my HVAC troubleshooting guide, first make sure the DCCV is behaving (post #2) and then proceed to post #4 for inadequate cooling. Please keep in mind there’s a good possibility of multiple faults, so don’t expect one magic fix. It may be several small things in play.
I’d suggest looking for a slipping clutch at the AC compressor. Details of how to check are in the guide.
#31
After that, work through the rest of the suggested steps for inadequate cooling. Just to confirm, selecting manual LO doesn't make any difference, right? And you did verify the DCCV is behaving?
The problem could be as simple as low refrigerant, but I'm not positive. I can't remember how much the RPM affects cooling performance when the charge is low. You had mentioned the AC compressor had been replaced. How long ago was that? Just trying to get a feel for when the refrigerant had last been fully charged.
#32
#33
I don’t mean this as beating up on you, but how does your friend know the clutch isn’t slipping? Is that just his hunch, or did he actually verify it with a jumper and paint marks? The root cause is probably a toss up between low refrigerant and a slipping clutch. But do you have to guess? Not really. It’s super easy to rule out the clutch for just a little bit of time and zero dollars.
#34
I don't know how exactly he examined the AC clutch but I kind of trust him as he's one of the best and most wanted mechanics in our country for high end cars.
Some of the customers come all the way from Austria or Germany to service their Porsche or Bentley at his garage!
He is also having his hand over my other cars wity twice the cylinders as the S-type
eathernet
09-03-2012 04:35 PM
Brizco88
20
03-08-2012 10:15 AM
