Finally all back together....but
Well after 5-6 days its all back together..replaced both knock sensors, did all new gaskets everywhere, cleaned out supercharger and did new SC oil,did both belts, new VC cover gaskets and plug hole gaskets, new plugs, redit the intake hoses with new couplings as suggested, new oil, new coolent.. what a crazy task.
but....im getting misfire p0303. so i swapped coils around and even plugs, cleared it all...ive done this 3 times, same result
p0303...so its not the coil obviously....i think im stumped
what do you mean about the gasket swap gong south ?
i put 3 different coils in that cylinder.. 2 of which are brand new..still shows misfire on 3
i have an acutron 9550..maybe it does.
Any way,
decided to do the good old fashion spark test... pulled the fuel pum fuse and cranked it whilst looking for spark..... the coil on # 3 was not giving a spark to the plug..
I put a different coil and got a spark. I took the the coil from #3 and plugged to another spot and did not get spark.. So it would all seem to point to a bad coil. SO ill get a new coil tomorrow.
But im not convinced putting a new coil in wil solve the issue due to the fact that I had previously swapped coils around and the codes still showed misfire on 3 so thats why this has been so confusing.
Any way,
Lol, meaning oil may be leaking into plug well fouling coil. And/or coil's plug wire may be chafed, leaking spark.
cant wait for a nice road trip !!
i surmise because I did not clear the original codes prior to doing a rerun...only possible explanation.. as a side point.. today i was getting a lean fuel mix code.. but then i remembered that the ecu stores the gas trim...so even though the coil was now fine, it was still dumping the fuel/air mix as if the coil was bad.
to clear that you have to disconnect negative battery for 10 min to clear the fuel codes.
i did that.. and NOW all if awesome.
so for future reference to all.. clear all OBD codes AND all fuel codes in between every reading
KarimPA
09-12-2015 08:15 AM
