fitting front fog/spot lamps
Hi just recently fitted front fog/spot lamps to my 2000 3.0 S type
my car never came with this option so had blank plates all the wiring was present
so I thought it would be a simple fit
the lights are all fitted and connected but theres no power to the front fog lights when you pull the headlight switch out checked all the connections and fuses im stumped at the minute as anyone had previous experience with this problem thanks
Jumpin' Jag Flash (12-28-2014)
abonano (12-28-2014)
I disagree. All three of our vehicles came equipped with factory fog lights. They can indeed be beneficial in light-to-medium fog conditions. But in heavy fog there's unfortunately not much you can do to improve visibility other than to stay home and wait for the fog to lift....
You turn on the switch to headlights and then pull the knob out to turn on the front fog lights and then another right click of the knob (that is now out) to turn on the rear fog lamps.
If your switch does not do this you need to source a switch that has the fog light option.
2000 jaguar s type 3.0 manual
My 2000 s type manual
has only one switch for the lights and fog lamp function, as it never had front fogs I decided to upgrade it as I got the lights for nothing and they mount straight in the bumper jaguar had pre installed the wiring so a easy fit
then no power to the front fog lamps i found that the switch is different so I fitted another light switch with the extra function for front fogs although it looks just the same it was a matter of plug in and everything works as if it left the factory
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
