FJT - removal of steering wheel control
1st move steering wheel out and down with controls.. then disconnect the battery as jag says.. lol i never do.. turn wheel quarter turn and with a torx 27 or 30 stick in rear of steering wheel .. there is a little hole .. there is a torx in there.. loosen then turn wheel opposite side and loosen off the other torx.. then airbag comes... out.. becareful with airbag connectors..
(i use a torx set that are long .. they look like a allen key set)
neiltonk (10-29-2014)
Long time I haven't posted, been pretty busy, put the reason is that I am changing the colors inside the vehicle. I stop I while back after changing the window switches and the parking brake because of other projects I had to do first ( bad cat). I just odered the smd's that will need replacing so I am back to working on the lights.
hunter34
19
09-14-2022 11:09 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
