Flashing climate control 05 stype
My climate control display flashes on and off rapidly at times. It seems to work fine whether it's flashing or behaving normally. Could this be a relay elsewhere or the module itself. Jtis only mentions the need for configuration of the module not remove and replace. Hopeful someone else has encountered this and/or might have a suggestion.
db
db
db
db
Mine did that just about a month ago.. Knowing how wacky the electronics can be.... Mine started flashing on the way to work so I drove straight to the dealer out of fear that it would go away and not repeat. The service guys came out and looked at it. Got a tech as well. The tech stated that it is a sign that the control module was on the verge of failure. They just replaced the control module under the Select Edition.
Hope that helps..
Just changed my DCCV and thermostat one week ago and since then no flashing! Since you said everything still works it seems we have the same issue. It may very well be we are/were watching our CCM in the first stages of failure. Too early for me to say, I'll feel much better if I still have no flashing after one month. But how old is your heater valve (DCCV)? If it's original I would think about changing it sooner than later. If my CCM were to quit completely there's an excellent repair by Justin67 look for his thread. Your right about one thing that flashing will drive you crazy. Good luck!
CCM flashing again. 12 days after changing out the DCCV the climate control module began flashing, so much for my hopeful preventive heater valve replacement. Seems my CCM problem is unrelated to the DCCV. So it would also stand to reason the DIY repair, which is due to a short in the CCM circuitry caused by a faulty DCCV is also unlikely to be the fix in my situation. Bummer.
When mine did that there were no codes present. It was inspected by the dealer while doing it. The tech, not service advisor, said that the display will flash when it is nearing failure. When I mentioned the DCCV had been replaced they came back with that as the cause for the module. Remember, just like you, I have not had any climate control issues with either fault. At this point I would actually contact the dealer for, at least, a second opinion.
I suppose it may even be true, but it sure sounds unlikely.
I have a "pretty basic" scanner that will read Jaguar specific codes but is not as good as the Autoenginuity scanner you've talked about. If it goes that deep, I may be tempted to get one myself. OK, It may... this link is worth a read...If our HVAC is part of the listed MCAN modules... But not sure...
http://www.autoenginuity.com/product...ware.html#EI11
Then there is the cost: http://www.autoenginuity.com/order.html
The base scan tool is 250 and the Jaguar add on is 230 for a total of $470 US. Plus a PC or laptop to run it.
AutoEnginuity will read the CCM and most other modules.
An elm327 will likely read the CCM if you know what commands to issue (data packets to send).
Using AE, last time I looked at the CCM I could see 26 values (as well as any actual DTCs):
Air Conditioning Driver Heater Sensor
Air Conditioning Passenger's Heater Sensor
Audible Tone Control
Battery Voltage
Blower Motor
Blower Motor Relay
Blower Motor Speed
Calculated External Temperature
Cold Air Bypass Servo Position Status
Control Module Status
Defrost Servo Position Status
Evaporator Air-off Temperature
Floor Servo Position Status
Heated Front Screen
Heated Rear Screen
Ignition Status
Interior Temperature
Left Interior Solar Sensor
Measured External Temperature
Number Of Permanent Diagnostic Trouble Codes
Number Of Trouble Codes Set By Diagnostic Tests
Panel Servo Position Status
Recirculation Servo Position Status
Relative Humidity Percentage
Right Interior Solar Sensor
Solar Sensor
Battery Voltage
Blower Motor
Blower Motor Relay
Blower Motor Speed
Heated Front Screen
Heated Rear Screen
Ignition Status
Solar Sensor
Gentlemen,
I did take the Jag to an independent jag mechanic who hooked up his OBD (don't know which model) and said there were no codes. However, I am also certain he's not as well versed as you two as to what to look for. I will probably get it in to the dealer if my next and last attempt to DIY doesn't fix it. I ordered a CCM on Ebay for $60 and with that in hand I'll check the original board for obvious fried circuitry. Thought I'd check/clean the sensors at the same time. Feel comfortable with the early and preventative swap of the DCCV. It was during that I also discovered that cracked plastic connection near the thermostat that also needed replacing. I'm in this for the long haul and once I get this figured out my plan is to address the IMT o-rings, oil pan gasket and the fitting/sleeve in the trans. A Happy Thanksgiving to you and all! Do you Brits celebrate the same date as us?
Gentlemen,
(no, we don't, but have a good one!)
