flashing touch screen
Hi All
Anyone had this ? -
When the lights are on auto and on - I sometimes get the touch screen flash from the night setting to day setting. It seems to be okay when the lights are switched manually (which is strange as the same system is probably used to dim it) The lights do not flicker with the screen change so I do not think it is the daylight sensor. I have checked its clean and also have cleaned the sensor on the mirror in case this was linked in as well, but it still does it
It does not happen often but is very irritating .......... any idea's ?
Anyone had this ? -
Since I don't have the NAV in Joyces Jag, I am not going to read all these threads https://www.jaguarforums.com/forum/s...earchid=664705 but maybe you will find your problem within.
