Flat Wiper blades replacing existing on S-Type
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I would like to replace the existing wiper blades on an S-Type 2005 3.0l V6 with the modern flat Aero type. I know others have done it with S-Types.
On this UK model the screen washers are on the blades themselves. I am not sure if all variants are built this way. Without taking them off I can't tell if the washer jets are detachable. I can't see any clips and they look like they are part of the blade itself but that may not be so.
Has anyone tackled this type and if you have can you offer advice of how to deal with the washer jets?
Many thanks in advance.
Received 2,636 Likes
I've just bought a set for my 2002 S type on eBay from one of the motor factors.
I checked on eBay and they do sell jaguar aero wiper blades with washer jets in the blade.
I pay an average of £6 for a pair which last 18 months to 2 years. Metal wiper blades make no sense anymore.
>I believe the windscreen washers are on the wiper arm, not the blades on later MY vehicles.
Actually, I believe the washer jet clips onto the wiper blade itself. I replaced mine last summer and remember removing the hose then detaching the blade from the arm bringing the washer with it. The wiper blades for our cars have a special "cut-out" for the washer and are unique.
Unfortunately, I believe Trico 15-240 and 15-190 are the only ones that fit... :-(
And they are getting hard to find.
Has anybody tried replacing only the wiper insert? If we could do that and retain the metal blade structure that would provide us with an alternative.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current Hers: '13 Lexus ES350
Current Mine: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past Ours: '05 X-Type 3.0/auto Jaguar Racing Green
I always replace ONLY the wiper blade inserts. The inserts must be "narrow" (meaning a claw width of 6mm, not the more common 8mm). The driver blade length is 24 inches and the passenger blade length is 19 inches....
While they are indeed becoming harder to find, I have always been able to order them through my local NAPA store. They never stock them, but they can usually get them for me by the next day or two. I usually order a couple of sets at a time, and that lasts me three to four years. The typical cost is $10 to $12 per set....
Many thanks for all your various insights.
It seems the existing washers won't clip off and on for re-use. Knowing that is a great help. I am still keen to use Aero types so will look for those mentioned with the jets built in.
It might be possible to find some after-market clip-on jets to use with standard blades or to fix jets in the plastic apron in front of the wipers. Has anyone tried this approach?
Thanks again for all your help.
I'm confused..., that is exactly how my blades and washers are designed. The wiper blade has a narrow place right near the attachment point with the arm. The nozzle clips there.
The problem is that very few wiper blades are available with that narrow space where the nozzle clips.
Have you removed your wiper blade from the car and inspected it? If you do you will find that you can wiggle the nozzle loose since it's really just a slide on/off connection.
Anyway that is what I have found for a North American 2008 S-Type.
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
I just took my 07 blades off, opened up the narrower opening on the NAPA Trico wiper blades, swapped the OEM nozzle clip and the new blades's(which is narrower than the oem so needed spreading) pin is thinner diameter so the OEM nozzle clip will not clip on.
I'm hoping the arm pressure will keep it pressed tight to the screen at the possible expense of a scratch on my pristine 10k windshield.
They are available.
Since reading the thread again I had a look on ebay uk and found some
flat aero wiper blades with washers for Jaguars.
A couple of examples I found:
Jaguar XJ Flat Wiper Blades Quality/ length.24"x19" With Washer Jets 2003on | eBay
S type 2003:
Jaguar S Type |2003-| Bosch Aerotwin Wiper Blades |Flat Style With Washer Jets| | eBay
For some reason ebay search is rubbish, but searching using Google shopping you can find them on ebay
S type 2003:
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
I found many of the cheaper aero types seemed to have much thicker frames and I was doubtful that the existing clips would fit. I did find some a set of "BOSCH AEROTWIN WIPER BLADES AR608S" at just £21.33GB with built in jets. At that price for the pair, with jets built in and for genuine Bosch I went down that route.
I know some have managed to re-use the OEM jets on standard blades though. You can try using a secondary fix; perhaps another clip that fits in the nozzle clip and over the side of the central fame so locking the two?
The new Bosch set hug the screen and give a perfect wipe. If you can get a set at a similar discount I think it might be worth it.
Busa (05-17-2016)
Yes the flat aero blades work a lot better than the OE metal frame wiper blades.
They update an older car's looks too.
I am fortunate to have bonnet washer jets so I bought a pair of aero wiper blades for about £7-00.
Thats more than I usually pay for a pair that last 2 years and only had to replace one when the flat wiper tip had a slight tear/cut.
I have in the past paid £30 each for good branded metal framed wiper blades and they dragged within weeks and needed replacing after 6 months. I was stitched up by an MOT test station.
https://weather.com/storms/severe/ne...lood-17may2016
jeffn (05-22-2016)
I tried to widen the space on the new trico blades they sold me as our OEM clips with the hose attachment is wider than the new Tricos. I spread them apart a bit but it was too much on a Johnson rod setup so I tossed the new blades and just used the inserts on my OEM blades.
And yes, our blades have some metal cutaway for the washer stream to run through to the winshieldscreen(my new Anglo-American term).
New inserts from now on only...
PbJag
19
08-31-2018 01:07 AM
carid
VENDOR 'For Sale' Classifieds
03-17-2016 07:11 AM
