Flyby Video Clip with new "Mafioso" intake
Received 9,007 Likes
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Our '01 has a p0420 and I pretty much have it narrowed down to the bank 1 catalytic converter, so that is my excuse to get some hi-flow cats. So it is going to be my test pig to see how good the local muffler shop is. Just need to figure out the best location of the O2 sensors and if you can drill a bung into the hi-flow cats, or is it best to put the sensors before and after the cats in the pipe.
On the STR I am going to leave the pipes at 2.25" with the new dynomax VT muffler so I am debating about leaving the stock resonators. What is everyones thought on the stock resonators? Are they very restrictive or flow through?
It will definately have resonators, just unsure if I want to leave the stock ones or go with glasspacks. Also planning on the hi flow cats with an X pipe. I know the X pipe helps balance the pressure but what other benefits and how does it effect the sound?
Interesting... Looked around and could not find any info on them. Anyone have a link?
Thank you very much.
#30
That is in the works...hopefully.
good luck.
Cheers!
#31
...be very careful about using the dynomax Vt mufflers, read a lot of negative reviews concerning the defective springs inside them to open and close the flap inside(there was a knock noise coming to my understanding). Many people had to do trial an errors to get the right one without the defect. Look it up on google and there's tons of stuff on this forum regarding exhaust systems especially Magnaflows etc.....
good luck.
Cheers!
good luck.
Cheers!
I read a lot of those reviews also. Supposably they have fixed this problem, but like you said it is still a chance if you buy from someone and they still have old stock. Not sure how to avoid this.
As far as the Magnaflows I like them but have read a lot about the drone they have in the 2000 to 3000 RPM range. I would also like to keep as much of that "sleeper" effect as possible when not in the throttle. The Dynomax VT seems to have the best of both worlds. Quiet at low throttle but nice and throaty along with the intake when you open up the throttle.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
dmatthewman
09-30-2015 10:10 AM
