Fog light bulb replacement
No, you don't need to do that.... Darn it, no JTIS when I need it!
The Jag fog lamps can be changed by pulling the trim on the front of the bumper and removing the whole lamp. It is much faster then removing the front wheel well liner.
I changed mine on the 05 I had. I changed the bulbs while servicing the car. Took the front wheels off and removed the inner liner. With the liner out you had a clear shot to the bulbs. Then a rock cracked one of the lamps and I had to replace it. Pull the surround trim and the lamps screw in from the front. Super easy to change. I used that same method to change the bulbs after that.
Do a search on this forum section and it should come up. Maybe someone with JTIS will also chime in...
pastype (02-20-2012)
Not on the S Type either. But the circuit loads are monitored for bulb replacement (why you need to add a resister to some lamps when changing to LED's).
Also, not a good idea to "tap" into a circuit, any circuit, to run fogs. All fog set-up's I've seen run their own relay. Again, you are putting too much on the headlamp circuit.
It's your car so feel free to do what you like. I'm just pointing out why I wouldn't recommend another user do this to their car.
Your comment is redundant. Repeating the circuit is monitored but never saying how.
Relays just switch voltage. They are cascaded. They do not monitor. Led's have built in resistors to operate internally. So if i follow you, when a bulb burns out a difference in line resistance will effect another component? Explain!
Again, your car so your choice.. I'm sorry if you are getting angry BTW..
Thanks.....
I thank you all for your input. Although, I only received anecdotal warnings without specific knowledge or technical references, I changed the power source over to the marker lights.
I apologize for posting this in the wrong forum topic thread. It was not my intention to disturb such knowledgeable and well formatted minds.
Tony K
03-26-2024 01:53 PM
