Fog Light Gremlin
Fog Light Gremlin
My 06 has a strange fog light electrical gremlin. If I've got the front fog lights on in the rain, and, I flip the brights on, the fog lights go off and stay off. Hitting the switch again won't turn them on either. I discovered that if I knock them off using the brights, I have to shut the car off, and, restart it to get them to work again. I'm assuming I've got a bad relay someplace?? Anybody else run into this?
Regards:
Oldengineer
Regards:
Oldengineer
Hi Oldengineer,
What happens if you turn on your bright lights first and then the fog lights? I have an 05 and I normally run this when it's dark. I was under the impression you had to turn the brights first in order for the fog lights work, but I could be mistaken. There also maybe a difference between the 05 and 06 model years.
Good luck,
Mike
Good luck,
Mike
Regards:
Oldengineer
Regards:
Oldengineer
Guest
Posts: n/a
Yes! I have replaced a bad Muti light switch for this problem, it was on a LS though....
When the Bright lights are on High, this will turn off the fog lights, it was designed todo so ,this wiil save alittle battery power and demand on the alternator.
It may also be a feature so you don't draw too much from your electrical system. The high beams, low beams, fog lights, brake lights, radio, A/C, etc. all running at the same time would draw a good amount of amps. Maybe even enough to make your other electronics not work properly. I could be completely off on this one, but I know when building old muscle cars this is a big issue which is why I have a 200 amp alternator in my Duster. Electrical is a pain in the ***, especially when you have a lot of gadgets and gizmos like our cars do.
My guess would be that Jaguar put it in as a convenience feature to prevent dimming gauges and interior lights.
Guest
Posts: n/a
Water and electronics don't work!
Water damage can cause bad grounds, because of rust (Cancer).
Lincoln LS had a recall on the plastic Cowl years ago, because of water damage.
Sorry , this is a post for another forum , a Dude having water problems & Misfiring.
The fog light was a bad Muti-light switch.
I just experienced this last night in my '06 as well. I was driving some country roads and illuminated the dark roads ahead with the brights but couldn't get the fogs to come back on. I had the light switch on Auto as well. Seems a bit odd and inconvenient for this to be intentional. Let me know if I should add this to the list of things I need the dealer to address.
OK, first of all. It is a DOT regulation for aux. driving lights, or fog lights that requires OEM's to deactivate them when the high beams are on. I had to double check that one and that is why it was not included in my original post. Also, a bad switch would always not work. Not just when you turned on the high beam. If you turn the stalk from On to Auto or vice versa, the fog lamps come back on (As long as the high beams are off). That would tie it in with the auto off feature. When the lamps are on Auto / with Delay, and you turn off the ignition, the fog lamps go out while the headlamps stay on for the designated delay. If you then restart the car, you then have to turn on the fog lamps, they don't just come back on. I going to bring this up with the dealer next chance I get.
Mine only work on low beam
Hi Oldengineer,
Good luck,
Mike
Good luck,
Mike
Regards:
Oldengineer
Ok, so I messed with mine this morning and couldn't get it to repeat with the headlamps on manually. There I sat like a dork flashing my high-beams in my workplace parking lot and each and every time the fog lamps returned when I switched back to low-beams. I know it still does it when in auto mode because it happened again last night. Again though, all I did was turn the switch to manually on and the fog lamps came back on, then I turned the switch back to auto and they stayed on. Still think it has something to do with the auto off feature. I am going to bring it up to the dealer next time I talk to them.
I agree with you
Regards:
Oldengineer
It was pouring rain here today, so I experimented a bit. My fogs work fine if the headlights are turned on manually - off with the brights, and, come back on with the low beams. On automatic, the fogs won't come back on when I switch to low beam, and, can't be turned on again with the foglight switch. I'll ask the dealer about it next time I'm there - but- the auto feature is definetly locking the fogs out if I switch to brights.
Regards:
Oldengineer
Regards:
Oldengineer
This has me real interested now. So, PHD, you have a 2003 STR, correct? The 05 and up STR has no front fog lamps. The common thing with everyone who has talked about the fog lamps going out then not coming back on while in Auto mode is that they are all 05 and up, non-R, cars. I wonder if there is something different in the programming in the 05 and up cars? It wouldn't make sense except for the little detail that they omitted the front fog lamps on the R, starting in 2005.
I don't think anything is actually wrong with our cars.. I just think it's weird.
This one is/was talking about two things... At first it was the fogs going off then not coming back. It was also brought up as to why the fogs go off when the brights / high beams are on. The fogs going off when the brights are turned on is the Federal Law / DOT. I don't know about Canada. The weird thing is if you have the headlamps on manual / low beam with the fogs on and turn on your brights, the fogs go out, then when you turn off the brights, the fog lamps come back on. This doesn't happen when the headlamps are in auto mode. When in auto, if you turn on the brights, then turn them off again, the fog lamps don't come back on. Here is where it gets real weird for me. If you then turn the switch to manual, the fog lamps come back on! It is just bizarre to a few of us... Man we must look nuts.. A bunch of S Type drivers out there switching their lights on and off and flashing fog lamps and high beams....
