Front supension "Bobbling" sound
Old 07-30-2010, 01:05 AM
bfsgross's Avatar
Panthro, you the man! Thank you very much.
Old 07-30-2010, 01:24 AM
Panthro's Avatar
No problem bro. I am the internet surf king. LOL!
Old 11-27-2010, 09:26 AM
bfsgross's Avatar
Ok folks. The cause of the front passenger clunk and bobbling wheel was the lower wishbone (runs from lower control arm to front member). Unfortunately replacement bushings aren't available for this part. Conventry West (Atlanta, GA.) promptly shipped a wishbone ($275) from a low mileage (50K) salvaged "S". Took the mechanic 30 minutes to make the swap ($35). Not only is she quiet over rutted surfaces, she tracks properly too. Side note: The mechanic advized me that Jaguar Heaven (CA.) would sell it to me for $200, but when I called they wanted $475 for the same part and said if I went "new" Jaguar sells it for $1100. Of course I knew he was full of s%$t (Jag wants $600). The mechanic called Jaguar Heaven and they said $475 was for both wishbone and lower control arm (again, full of s*&t). Call around folks. I found Coventry West knew more "Jag" and gave for less $$.
Old 11-27-2010, 10:49 AM
MyBlackCat's Avatar
This is a very common problem with the 03 and up S types
Had all mine changed recently front and back. Cracked or leaking boots on the bushings. Sway bars also.Probably would have only done the ones that needed it most but because of the warranty a $3500.00 bill turned to a $100.00 with alignment also.
Old 11-27-2010, 11:33 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Not ideally local (!) but many bushes etc are available as on this thread:
"The definitive wishbone bush thread" http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=34593
Old 11-27-2010, 01:21 PM
jag79's Avatar
Originally Posted by Panthro
Hey bfsgross, I found this on the "other" site. Hope it helps.
Panthro share with us your findings , who knows it might help out others also.
Old 11-28-2010, 05:53 PM
bfsgross's Avatar
jagv8, last month i asked you on a PM if ya knew the thread to find a bushing for the control arms. You wrote that you didn't know.
H20boy
07-23-2021 09:39 PM
mbergen
10-23-2019 10:26 PM
GordoCatCar
01-02-2017 01:10 PM
Daim
11-28-2016 09:28 AM
simo5555
09-09-2015 06:22 AM
Quick Reply: Front supension "Bobbling" sound
