front suspension alignment specs, the updated ones.
I think these are the TSBs:
TSB S204-12 Excess wear on the inner edge of the the front tyre treads. Modified toe specification
TSB S204-S150 Campaign - Rear Wheel Alignment Inspection/Adjustment - Check/reset rear toe
and this is the best I have:
front camber >2002.5MY in degrees:
RHD L -0.6+-0.5, R -0.2 +-0.5, R-L 0.4 +-0.7
USA,etc L -0.2+-0.5, R -0.55+-0.5, R-L -0.35+-0.7
ROW L -0.2+-0.5, R -0.4 +-0.5, R-L -0.2 +-0.7
front toe >2002.5MY in degrees, (all areas) -0.2+-0.17
but TSB changes USA to +0.1
toe specification front & rear, also camber etc
Jag changed front from toe out to toe in?
front toe +0.1 degree
(see S204-12)
toe in 1.5-2mm
rear camber >2002.5MY in degrees:
(all areas) L -0.54+-0.75, R same, R-L 0.0+-0.75
rear toe >2002.5MY in degrees (R only):
(all areas) L 0.13+-0.1, R same, total 0.25+-0.17, thrust angle 0.0+-0.1
(see S204-12)
toe in 1.5-2mm
2007, alignment, allignment, front, jaguar, pictures, s20412, specification, specs, suspension, toe, tsb, xj, xkr, xtype
