FUEL COMPUTER DATA ERROR
Guest
Posts: n/a
Hey guys, just started her up tonight and a few things happended. first off the information display read FUEL COMPUTER DATA ERROR. the ac is locked at 73 farenheit and if I try to change it, it will automatically switch back to that temp/ setting etc. the blinkers are also clicking fast as if one were out, but they both function correctly on the outside. the fuel gauge also is at E even though I have a full tank.drives fine though. anyone experiece this and or have a diagnosis?
Thanks in Advance!
Thanks in Advance!
ORIGINAL: whitestype
was just wondering if any1 thinks you should disconnect the battery every once in a while to recalibrate the computer?if so how often and has any1 ever done that?
Seems like others are adopting this method of fixing intermittentcar computer errors, rather than allowing the dealership to steal their $1500 replacing the computer.
Guest
Posts: n/a
I have had a similar problem driving along motorway and all dials set to zero and revs stayed high, message "Fuel Data Computer Error" shows. Recovery truck got fault code 1638 and filed down earth points,.. car worked. One week later same thing happens, garage take it in and find one corroded earth point and one snapped on the battery tray. Replaced today,.. and guess what happens driving home? - yep same thing.. am seriously hacked off.
About the disconnecting battery thing,.. I don't know much about cars but I know this can't be the best idea! Also fault codes are stored in the computer until reset.
These peculiar and random "computer errors" can be down to a bad battery; there have been lots of posts on this one. My last one suggested strapping a good second battery with jump leads across the vehicle's own battery, propping it up with concrete blocks in the boot/trunk. Then going for a drive or two to see if problem fixed. The Jag. ECU's are known to be sensitive to battery voltage. During cranking, the voltage of a good battery i.e. one with enough amp/hours, shouldn't drop below about 9volt. The heavy current of 600amps or so is also slightly 'impulsive' due to the brushes in the starter motor and their contact with the commutator. These "spark" quite a lot although you can't see it of course. Sparks and microprocessors? BAD NEWS!
Leedsman.
Leedsman.
There's a recent post about going through the heavy current battery circuit, it's not simple, there are 'protection devices'. Any minor corrosion anywhere in securing nuts etc. can cause subtle sparking during cranking which could affect the microprocessors. You're getting in the long grass now, can't help much more.
Leedsman.
Leedsman.
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
FAO. Mcadame, can you read off the number on said diode and let me know? Then I can tell you what type of diode it is (silicon, shottky, zener, etc.) and if it's in my books its rating (PIVvolts, current etc.). Then I might guess as to its purpose. Diodes always have a ring printed on them if they are cylindrical in shape indicating polarity.
Often they start 1Nxxxx. Such semiconductors are almost always very cheap.
Leedsman.
p.s. When such diodes go wrong, they always go deadshort. A common ohmmeter will test them. If not soldered in, subtle corrosion is a possibility on leadouts.
Leedsman.
Hey guys, Ive read the old post about disconnecting the battery which I plan to do, but I also have with this problem at the same time the sunroof quit working along with the rear windows and the park lights are remaining on long after I have left the car. Are those related and will the battery disconnect also solve this as well.
Austinmartus
Thanks for the reply however I have several other problems with the fuel issue. I have disconnected the battery and it worked for a short time but the problem is back with a vengence. Now the lights dont work properly, the turn signals blink fast and dont work in the back, the windows are not working properly as well as the sunroof.
I think if is a computer issue and i need to know which and where to look. One mechanic said it is the instrument panel and may need to be replaced.
2000 jag s-type
2000 jag s-type
