Fuel filter replacement, 03 str , need some advice on how to change lean bank codes
I have done extensive work to my car, new supercharger, aux pumps, sensors , cats, water pump, and several other updates. I'm getting a lean bank 1 and lean bank 2 code. I'm thinking it's fuel filter , never changed , 178 k miles, any advise ?? Thanks in advance
Not trying to be flip, but how on earth could you replace all those parts but NOT the fuel filter? My opinion is that they're good for 30k miles, maybe a tad more. My advice is that you replace it pronto, then see if lean codes go away. And by the way, cut the old filter apart; I think you'll be surprised at what you find.
A) change the damn fuel filter. There is even a youtube vid that member vance created for ease of replacement.
B) maybe that is why you have done "extensive work" over a $10.00 fuel filter and less than a half hour to replace it.
Almost 100% sure it's not the fuel filter but it's good to change it anyway.
Have you checked the P/B vacuum hose connection on the back of the supercharger elbow? A well known vacuum leak. Yours will be bad at this time and will crumble when you touch it. Will require the SC to come off to repair properly.
Did you replace the blower or paid someone to do it? I hope the under super charger coolant hose was changed at that time. If not add that to your list when checking the P/B fitting.
Also check the plastic intake tubing and noise chambers for holes and cracks. Our cars are old and I just found the plastic on the intake is getting brittle and I have a corner that has disintegrated and looks to have a hole in it. Some black RTV patched it up.
But until you can monitor your fuel trims while spraying carb cleaner on different spots you are shooting in the dark.
Also I hope you have serviced the transmission with that many miles on the car!
