fuel injectors
I add Lucas fuel injector cleaner ever other tank..
My problem is the previous owner was horrible at doing anything for this car. I am sure it put the cheapest lowest octane crap he could in it..
After I bought the car I changed the original fuel filter and it looked like mud comming out of the out fuel filter.
This drives me crazy and I really want to make sure they are cleaned right for proper fuel mileage.
They last tank of gas I have got my car when first started idles rough then 10 seconds later smooths out and runs perfect.
Just to be on the safe side I want to check them out.
Received 2,193 Likes
its easy to take them out and you can send to InjectorRx - Professional ultrasonic fuel injector cleaning, flow testing and balancing service.
they give a before and after performance printout, ultrasonic clean and replace screens and orings. All for $18ea theres nothing better to clean and injector and theyll perform like new again. tank and onboard cleaners will not clean anything out of the injector basket screens, besides Ive pulled many a Jag injector and todays additives and ethanol eats away the baskets
Jumpin' Jag Flash (12-19-2016)
Sounds awesome, does the manifold have to come off to remove injectors?
No just the fuel rails, use compressed air to blow all the dirt off and away from the injectors before removing, and when you reinstall lube the orings and slides straight in so you dont cut a orings. Thats not easy to do (cut an oring) cause the openings are chamfered, but still be carefull
pdf files from JTIS with removal/instalation instructions for :
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Fuel pressure regulator.pdf
Hope tis helps
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Hope tis helps
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Hope tis helps
Fuel Rail.pdf
Fuel Injectors.pdf
Throttle body.pdf
Hope tis helps
Can someone please post new links?
Received 2,263 Likes
This has nothing to do with the injectors.
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
XKE73EIconverter
09-26-2015 10:21 AM
