Fuel problem/gas cap? fuelpump?
Guest
Posts: n/a
Hello: Everyonce in a while when coming to a stop my 2000 stype will die. Restarting is no problem. The other day after stopping at the store, the car would not turn over there was almost a full tank of gas. I was told it was a fuel pump as he could not hear it working and power was getting to everything. The mechanic changed the fuel filter and it ran fine so he did not replac the fuel pump. Then the next day I stopped at a stop sign an it once again died and hen restarted. The car has 53K miles on it and runs great. The mechanic suggested I change the fuel cap since it in ten years old. Any thoughts on the fuel problem.
I cant see the cap making a lot of difference as I believe our tanks have a good breathing system
I would have thought it was more likely to be a electrical or injection problem as you have fuel running through the filter
what engine have you got as the V6 suffers from vacuum hose air leaks and it may be that
