Fuel Trims help
Fuel Trims help
Hi I have a 1999 S type V6 3000cc
ive had problems for quite some time and I think I知 narrowing it down to an air leak but I might be completely wrong I値l include to photos showing fuel trims one at idle and one at approximately 3000 rpm
if anyone could help and give me a clue as where to look I would much appreciate it
thank you .
thank you .
Here's a good primer on troubleshooting with fuel trims:
JagRepair.com - Jaguar Repair Information Resource
But before digging too deeply, look at your fuel pressure. Looks okay In the first picture (idle), but in your second picture it's too low. I'd investigate further and take care of that first.
Fuel trims
Thank you for your reply I have been looking into the fuel pressure for quite some time now I replaced the pump and after one week the fault appears again so I thought faulty pump so I replaced in with another from a different company lasted 4 weeks and then back to square one fuel filter has been replaced injectors replaced inlet manifold gaskets replaced , crank sensor replaced plus many more parts already done.
so I知 running out of things to look for ☹️
VPinGA
02-23-2022 05:21 PM
