Full flow exhaust / ECM-Air/Fuel monitor
Hey guys; As many of you know, I've replaced my motor with a Jaguar re-manufactured 4.2L with the Snake Bite blower kit. I've also installed a full flow exhaust system using the existing piping and cutting/welding the new parts in place, as follows:
Here is what I installed:
Exhaust tips- 2 Magnaflow part # 35190 @ $73.23 x 2 = $146.46; Resonator- 2 Magnaflow part # 11226 @ $63.05 x2 = $126.10; Muffler -1 Magnaflow part # 11386 @ $80.29; "X" pipe- 1 Magnaflow part # 10791 @ $67.86; Cat Conv-2 Magnaflow part # 54976 @ $65.83 x 2 = $131.66
All parts ordered from www.performancepeddler.com (best pricing I could find. (This system barks on acceleration, but is not irritating at cruising - feels like substantially more power, but undocumented). I will visit the DYNO shop soon.
I also purchased the OT-2 (OBD II/ECM) monitoring sysetm and the LC-1 (Air/Fuel) oxygen sensor monitoring accessory from:
www.innovatemotorsports.com
I can monitor/data log ECM functions and air-fuel ratio with this system on either my laptop or my Iphone (there's an app for that) - Cool. It will even estimate my HP, and 60ft, 1/4 mile times and speed. (these are estimates)
If you shop on e-bay, I got this entire set-up (two different auctions) for about $320.00.
photos and video-sound clips to follow (weather permitting)
No, I didn't do a hard reset, but I have no DTC error codes either. Seems like everything is working fine.
cheers.
ttwotees, def. do a hard reset after a mod of this magnitude. I've poked around the XJR and XKR forums and they re-set after pulley and an exhaust mods. The ECU will discard existing parameters and learn the new. One other thing, does the Magnaflow dual inlet/outlet resonator have an internal cross-over tube? If yes, then I wonder if this negates the productivity of the x-pipe?
Aus V8S
11-13-2015 11:01 AM
rachelstr
09-03-2015 12:59 PM
