Fuse blown/ battery sign is on PLEASE HELP!
Guest
Posts: n/a
I have a 2000 Jaguar S type 3.0.....I recently installed some H.I.D.s...after a day or so my fuse
11 mini 15 Blue Heated oxygen sensors, air conditioning clutch coil relay in the egine compartment
Keeps blowing everytime I turn on the car. is there a relay I need to replace or sometin.
Also My battery sign has started to come on I unhooked the H.I.Ds but light stay on.
Had check engine light dyno and it say alternator has low output is there a relay switch for the alternator?
Received 3,894 Likes
Shawty, check fuse #11 in the front distribution box. If that is blown, that can be causing your battery light to come on. If it isn't that, then check fuse #5 in the rear distribution box. Either one of those can cause your alternator to not play nice. Since you are not complaining about the car not running or shifting funny, I can assume that your powertrain control module is working fine (controls the output voltage of your alternator).
As for your HIDs causing issues, where all did you connect up wires? This will help me figure out where your problem may lie and give me a few points to tell you to check.
Guest
Posts: n/a
It is shifting funny also. The probelm started when I changed Headlight assemblies. I hooked the H.I.Ds back up but on the driver side not enough voltage came from the harness so I ran it through the fuse box with a switch to get 12 volts to power the light without flickering. I believed it touch the number 11 fuse and blew it. How ever when ever I try to replace the fuse it blows on ignition. As far as the battery sign it's not being charged by the alternator. Do you think the Alternator went bad? I had the Battery recharged and it dies after a couple of days.
Guy-Pierre Boucher
09-16-2015 05:55 PM
