Gabriel S-type R build thread
Check out this site and scroll down to the finished header part.They have a you tube video on their process of construction.This is a Ghia build (I am into Ghia's)but the info on the headers is interesting.It won't be cheap but in my experience no customization or special fabrication comes cheap.
www.deanzrodzandracecarz.com/sidewinder
You may be interested in this sort of tool:
http://www.autospeed.com/cms/A_1973/article.html
(other tools, such as the one from AutoEnginuity, can also be used)
Bad news the reroute of the intake was a big failure. I thnk i bottlenecked the air flow which resulted on very bad dyno results. I got 256rwhp with the intake rerouted I immediately removed the intake and used the stock because I figured the car was gasping for air. So back to square one, I will go ahead and develop a carbon fiber infender intake, then plan on purchasing a tune with pc mention by jagv8, because I plan on using the dyno a lot I dont want to pay 40 everytime. I will keep you updated.
You might also like this:
http://www.autospeed.com/cms/A_1898/article.html
the snag with the STR is that it is full of electronics and software, which will get in the way of simplistic mods!
#30
#31
I felt the difference when I put the stock one back. I just used the big cone filter intead of the stock box.
#32
#33
Progress: i have started on the intake system and will probably finish mock up Saturday. After that I will make mold and make th intake tibing out of carbon fiber.
Cosmetic: I purchased H&R lowering springs. I also have my choose down to two wheel options. Pics up soon
#34
wheel have the new springs installed and rims as well, had to pull rear fenders since it was scrapping on bumps. I also removed the rust of the shock ansorbers an coded the shocks with new red paint. I also tinted the car and polished the emergency brake caliper in the rear.
Old shocks with rust
![](https://www.jaguarforums.com/forum/members/super_jag-1681-albums-super_jag-13-picture-img1258491816030-2658.jpg)
New shock with paint and spring
![](https://www.jaguarforums.com/forum/members/super_jag-1681-albums-super_jag-13-picture-img1258491890892-2657.jpg)
Spring height comparison
![](https://www.jaguarforums.com/forum/members/super_jag-1681-albums-super_jag-13-picture-img1258491858662-2581.jpg)
#36
After building two of these engines I would NEVER put nitrous through them!
As far as the intake goes, you are finding out the truth. The prefabbed kits do almost nothing and homemade ones are usually worse then that. You will hear claim after claim about feeling the difference which is bs. IF you are hell bent on making an intake, the first step is finding a path that avoids heat, much like you have. The second is maintaining or exceeding the pipe diameter in all areas EXCEPT the MAF sensor. This can be tricky as alot of stock intake tubes are oval. People think they are going bigger when they are actually going smaller. On top of ALL this, you have to avoid as many turns as possible, air does not bend, 90* angles in these intake kits are notorious for hurting air flow.
There is a performance way to go about improving the intake IF you want to do it right. First of all, install a vacuum gauge and do a WOT pull on the dyno. This will show the intake restriction, if any, your engine is fighting against. This will tell you if your work is even worth it. Second, with a scanner, watch the IAT. Typically the car manufactures put these air boxes in a pretty good place from the factory (remember, they don't like high IAT's either). So, the only real improvement are impratical (the kits that route the filter inches off the road) because the factory is going to take a higher IAT over the chance of water being sucked into the engine.
A major improvement on these cars is the exhaust. The entire exhaust system is pretty restrictive from the factory. That's normal on a "luxury" car because most owners will sacrifice some power for a quiet cabin.
#37
#40
Just saw this...sorry. I'm pretty sure he told me, but I can't remember. Did you ever find out who it was?
