Gas filler door popping open
Old 02-02-2011, 08:17 PM
mikewv100's Avatar
Default Here is source for striker for fuel door
http://www.jagbits.com/mm5/merchant....pe_FuelDeliv_2
Here is plastic latch that repeatedly breaks part number XR818050
The following 3 users liked this post by mikewv100:
aholbro1 (02-03-2011), Alvin Burns (02-26-2011), IvysMommy (01-16-2020)
Old 02-03-2011, 10:28 AM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
Default Great Find! Thanks for the link
$15-n-change plus shipping.
Finally ran across thos pics I mentioned. Guess I was making $8-$10 per hour when I did this....
Attached Thumbnails Gas filler door popping open-pc240508.jpg   Gas filler door popping open-pc240513.jpg
The following 2 users liked this post by aholbro1:
IvysMommy (01-16-2020), Travelchic (01-05-2012)
Old 08-22-2011, 02:29 AM
Nerius's Avatar
Don't want to create a new thread so I'll just post here.
I have a similar problem with the 05 S-type. The tiny plastic pin broke and now there's nothing to hold the door in place. I tried to fashion something out of metal but it's difficult to access. Does anyone know a part code for that pin and what needs to be replaced?
Maybe some other makes/models used the same part and I could look for a used part?
Thanks for ideas.
Old 08-22-2011, 03:40 AM
Nerius's Avatar
Is it possible that this is the part number to be replaced in case of broken pin: XR855934 link?
I saw that Jon also mentioned this to be replaced in his case.
Old 08-22-2011, 10:41 AM
Jon89's Avatar
Received 4,360 Likes on 2,851 Posts
I doubt if Jaguar will sell you just the plastic latch pin. In our particular car's cases, the entire assembly was replaced each time, all under the factory warranty. I now keep the mechanism lubricated with white lithium grease, and the third replacement seems to be the one that finally fixed it....
Old 08-22-2011, 10:46 AM
cryhavoc38's Avatar
06 S Type R that appears to be missing the plunger.
I read that the Dealer sells a replacement plunger/guide kit, so I'll go that route. Pretty sure the plunger isn't seized in there since its just a black hole of need..
must have popped out on the previous owner who was too busy to just get it replaced.
Old 08-22-2011, 10:57 AM
Nerius's Avatar
Jon, do you have any idea if the XR855934 part has the latch pin?
I don't expect the pin to be a separate part but from the images it's hard to judge if that's the correct mechanism.
  #28
Old 08-22-2011, 11:13 AM
Jon89's Avatar
Yes it does, but it also includes the motor, the actuator, and various other bits and pieces that comprise the fuel filler door system. I doubt if you want to spend several hundred dollars just for that lousy latch pin. If the pin is all you need, there must be a better way to obtain (or fabricate) it....
Old 01-05-2012, 07:47 AM
Travelchic's Avatar
Default What the Heck!
Guess this is common... my fuel door striker needs to be replaced as well. No wonder they had it in stock.
  #30
Old 01-05-2012, 11:19 AM
totalimmortal363's Avatar
I just removed the latch spring until I can get around to replacing the required part. Came out with my hands and it can be put back in once I buy the latch mechanism.
After you pull the spring the door will sit flush again and so far hasn't came open while driving at all.
Here's the spring. You can see the notches where it comes out and can be reinstalled.
  #31
Old 01-07-2012, 02:15 AM
dujaguar's Avatar
This one drove me nuts. It has happened numerous times. But mine was hanging up closed and would not open, no matter how many times I tried the release. I used WD40, that didn't work very long. I used 3-1 oil. And that worked for a few months. But the problem persisted. Until one day, when I used Liquidwrench dry lube spray with TFE. That was 2 years ago. Bingo!!! that reminds me to spray it once more, before I have the problem again.
  #32
Old 01-07-2012, 02:19 AM
dujaguar's Avatar
Just remember to use Liquidwrench with TFE dry lube spray. It's the best solution for this flimsy mechanism before and after you install the pin. cheers.
99xk8guy
05-28-2024 09:36 PM
99xk8guy
06-05-2023 06:28 AM
GordoCatCar
01-02-2017 01:10 PM
XJsc-guy
11-23-2015 01:56 PM
Aus V8S
11-13-2015 11:01 AM
Quick Reply: Gas filler door popping open
