Gas filler door popping open
http://www.jagbits.com/mm5/merchant....pe_FuelDeliv_2
Here is plastic latch that repeatedly breaks part number XR818050
The following 3 users liked this post by mikewv100:
The following 2 users liked this post by aholbro1:
IvysMommy (01-16-2020),
Travelchic (01-05-2012)
Don't want to create a new thread so I'll just post here.
I have a similar problem with the 05 S-type. The tiny plastic pin broke and now there's nothing to hold the door in place. I tried to fashion something out of metal but it's difficult to access. Does anyone know a part code for that pin and what needs to be replaced?
Maybe some other makes/models used the same part and I could look for a used part?
Thanks for ideas.
Thanks for ideas.
I doubt if Jaguar will sell you just the plastic latch pin. In our particular car's cases, the entire assembly was replaced each time, all under the factory warranty. I now keep the mechanism lubricated with white lithium grease, and the third replacement seems to be the one that finally fixed it....
06 S Type R that appears to be missing the plunger.
I read that the Dealer sells a replacement plunger/guide kit, so I'll go that route. Pretty sure the plunger isn't seized in there since its just a black hole of need..
must have popped out on the previous owner who was too busy to just get it replaced.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I don't expect the pin to be a separate part but from the images it's hard to judge if that's the correct mechanism.
#28
Yes it does, but it also includes the motor, the actuator, and various other bits and pieces that comprise the fuel filler door system. I doubt if you want to spend several hundred dollars just for that lousy latch pin. If the pin is all you need, there must be a better way to obtain (or fabricate) it....
#30
I just removed the latch spring until I can get around to replacing the required part. Came out with my hands and it can be put back in once I buy the latch mechanism.
After you pull the spring the door will sit flush again and so far hasn't came open while driving at all.
![Name: photo2-1.jpg
Size: 44.9 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/167434d1501278365-gas-filler-door-popping-open-photo2-1.jpg)
![Name: photo1-1.jpg
Size: 69.1 KB](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/167435d1501278365-gas-filler-door-popping-open-photo1-1.jpg)
Here's the spring. You can see the notches where it comes out and can be reinstalled.
#31
This one drove me nuts. It has happened numerous times. But mine was hanging up closed and would not open, no matter how many times I tried the release. I used WD40, that didn't work very long. I used 3-1 oil. And that worked for a few months. But the problem persisted. Until one day, when I used Liquidwrench dry lube spray with TFE. That was 2 years ago. Bingo!!! that reminds me to spray it once more, before I have the problem again.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Aus V8S
11-13-2015 11:01 AM
