Gas Peddle Push
I would think that since my screen name is ILuvmy05 STR and that this post is on the S-Type thread, that it would be pretty obvious what type of car I'm talking about.
So I'll catch anyone up to speed who is to slow to understand.
I'm talking about a 2005 Jaguar S-Type R.
I hope that clarifies it!
jagV8- is this the section you're referring to:
Kickdown
Kickdown is operated when the
accelerator pedal is pressed fully down,
beyond the normal operating spring
pressure, to provide maximum engine
performance. Kickdown is used in
circumstances where rapid acceleration
is required, such as when overtaking.
Kickdown causes the transmission to
change down to the lowest gear possible
to achieve maximum acceleration. The
gear engaged depends on the road speed
at the time of kickdown.accelerator pedal is pressed fully down,
I have had previous cars that physically lift the gas pedal when the traction control kicks in but I haven't noticed it happen in the Jag (maybe I'm just use to it). The traction control does seem overly intrusive and can kick in at just about any speed. I've read the manual pretty thoroughly but don't recall anything that mentions it? Seems like it would be more helpful if others could just say what they know instead of turning it into a guessing game.
OK.... I thought it would be in the handbook. It should be, whatever it is.
Failing that, I was after more information. So many questions are asked with so few details and somehow it's the fault of the people who try to reply. Fixed if no-one replies![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Many fairly recent cars had a throttle cable so if TCS or the like took over then that cable could be yanked around. The jag doesn't have that AFAIK. Still, the effect sounds like DSC/TCS and you'd think it would be described in the handbook. Suppose it doesn't actually shove on the pedal, it could still be that there's a bit of actual or near wheel-spin with braking which a driver interprets as pedal movement. Would that be in the handbook? Maybe not. How would an observer decide? Dunno! My best guess would be TCS, though. If it is that, it may be unfixable or there's a problem such as worn tires, suspension, eek so many things. One would be: expecting the car to do the impossible i.e. hitting the pedal too hard lol ("I cannae break the laws of physics." Did I quote OK?)
Received 2,263 Likes
Check the floor mats.
There is no mysterious gadget to move the pedal. It a swing arm connected to a potentiometer with a return spring. Thats it. So either there is a driver error or your floor mats are getting up and behind the pedal OR the pedal is wearing out and has points of friction in it.
Furthermore, it is not very intelligent to make negative comments about people that are just trying to help. Alot of people on these boards have more than one vehicle and their usernames don't always reflect that.
If you don't believe me, put your car in neutral with the engine running and flooring it. It should go up to a certain rpm (3,000 I believe) and stay. you can let off the peddle and you will see that the last 1." or so is just freeplay, doesn't change engine rpm's at all.
I think that what is felt is the full throttle detent.... I feel that when I drive mine. The throttle becomes "harder" to push when you floor it. I've noticed this since I do it often....'cause I drive a lowly 3.0. As I've posted before, a V8 car would have suited my driving style better.... I'm waiting for one of the message displays in the car to display "Hey dumb*ss, I'm not a R!".
