"Gearbox Fault" Problem.. Need help badly!!
So back to the list of things posted before. Bad sensor(s), wiring, connector(s), air leaks, etc. Any new codes, especially engine codes, probably mean something about the recent work done has caused them. If you don't know how to cope, find a tech who does.
From your long codes list you're in a unique category on here so be realistic as to the chances anyone can solve the problems via a keyboard.
I know it has been a while since I wrote but I just finally came up with the money to bring it to someone else and get it checked. Thanks to the guys here at Portland Transmission (290 Smith Street Providence, RI 02908) they found that it wasn't anything mechanical, it was infact a wire that was shorting out. I unfortunately forget to ask which wire it was because of my hapiness that it was fixed but I will find out and let everyone know what it was exactly. I'm happy that this problem is solved but now I have another issue which isn't as bad as this one but I will start a new feed about it so im not discussing two topics in one feed.
Thanks for all the help in this feed and you guys were completely right, just needed to be seen by someone with the right equipment to diagnose it.
Norri (01-07-2012)
#28
Received 6,337 Likes
#30
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
