Got the Check engine light twice now.
So after picking up my car and driving about 1000 miles home with zero issues, yesterday I got the check engine light and restricted performance "memo".
Today I dumped the info at Autozone and this is what I got:
P0171 bank 1 too lean
P0174 bank 2 too lean
P1111 unknown
P1000 mod $11
I elected to erase the codes and see if anything reappears.
The P1000 unknown would not clear.
But the check engine light went out and the car returned to normal operation.
Prior to me picking up the car I had a PPI done at the local Jag dealer and they identified some pre-existing codes which from their verbal description sounds an awfull lot like the P0171 and P0174.
I have not touched the car at all but maybe as a result of their inspection they left the hose between the MAF sensor and the intake loose and it's leaking?
This is a car with 14.5K miles and it's a 2005. The only official records of Jag service are oil changes and an oil pan gasket replacement.
They recomended an injection system cleaning proceedure (?????), new air filter & cabin filter plus a brake system flush. No arguments with the filters and flush. Cooling system too!
So after reseting the codes it threw another set not too long after that so I read them again.
P0171 bank 1 Mode $11
P0174 Bank 2
P0171
P0174
P1000
Then I read some parameters
P0174 @ 623 RPM (seems like a very low idle)
ABS TPS% 3.5
Load 16%
MAF lb/m .89
MAp ("HG) 14.89
Coolant 203F
IAT 108F
Ign. Adv. 7.5 degrees I assume
ST FTRM1 % 3.1
LT FTRM1 % 18.8
ST FTRM2 .8
LT FTRM2 18.8
Veh speed 0
Fuel PSI 56
Fuel sys1 clsd
Fuel sys2 clsd
Most of this is Greek to me but that's ok.
So what do you guys think?
Maybe a new fuel filter and injectors cleaning via their treatment or do I have a couple of compromised lamda sensors? Maybe just a bottle of Techron for the injectors???
How hard are the lamda sensors and fuel filter to replace?
Bob S.
P1111 unknown
P1000 mod $11
P0174 Bank 2
P0171
P0174
P1000
ABS TPS% 3.5
Load 16%
MAF lb/m .89
MAp ("HG) 14.89
Coolant 203F
IAT 108F
ST FTRM1 % 3.1
LT FTRM1 % 18.8
ST FTRM2 .8
LT FTRM2 18.8
Veh speed 0
Fuel PSI 56
Fuel sys1 clsd
Fuel sys2 clsd
Bob S.
mine is modified, but the first code didn't rear it's head for about 8 days and probably about 300 miles of driving. I think I found my vacuum leak on the spacer between the charge cooler and supercharger hat (supercharger discharge casting). I didn't expect problems with my car with 38 k miles, but stuff happens.
All P1 codes are make-specific and the car maker can at their choice even make them model-specific and/or year-specific.
P1111 is best understood by looking it up in the workshop manual. It's a status code that all S-Types should have.
P1000 - also see the workshop manual. It should not occur with P1111 as they are opposites!
I think "mod" is a daft abbreviation for "module" (as in PCM, TCM or whatever).
AutoZone only read the PCM, I understand.
$11 is the code for the PCM on an S-Type.
I don't mean to be awkward but there's good stuff in there and I can't even copy/paste it in here.
ABS TPS% 3.5
Load 16%
MAF lb/m .89
MAp ("HG) 14.89
Coolant 203F
IAT 108F
ST FTRM1 % 3.1
LT FTRM1 % 18.8
ST FTRM2 .8
LT FTRM2 18.8
Veh speed 0
Fuel PSI 56
Fuel sys1 clsd
Fuel sys2 clsd
ABS TPS% 3.5
Load 16%
MAF lb/m .89
MAp ("HG) 14.89
Coolant 203F
IAT 108F
ST FTRM1 % 3.1
LT FTRM1 % 18.8
ST FTRM2 .8
LT FTRM2 18.8
Veh speed 0
Fuel PSI 56
Fuel sys1 clsd
Fuel sys2 clsd
Idle rpm's about right.
ABS is absolute (cf relative), TPS is in my acronyms LOL. Rarely gets down to 0 but 3.5% is no throttle. MAP is measured in inches of mercury (so, " and Hg). Looks OK.
Coolant (ECT) shows engine was hot.
IAT shows it was quite a warm day.
LT FTRM1 & 2 are long-term fuel trims for bank 1 & 2 and show you have an air leak.
You'd hope for trims below 5%.
Also, both banks are the same so there's a good chance you have a leak in a place that's common to both banks.
"clsd" is "closed", meaning "closed loop", i.e. the PCM's controlling fuelling etc using feedback from the sensors especially the O2 sensors. (It won't even try to do that when starting but we can tell the car's not just been started from all the other values.)
I wouldn't mess with the injectors now, either. Change as few things as possible until you find the air leak.
Thanks for the input. You seem to think this is probably all air leaks post the MAF?
I haven't even looked at this yet but do you suppose this is as a result of someone loosening up the hose from the throttle body to get the air filter out?
I'm taking a "I'm not going to touch it" approach since it got a clean bill of health at the Jag dealer during the PPI and it's now going back to another Jag dealer tomorrow for this and the headlamps. But I might take a look and see if it feels loose. Other than the oil and filter change at the BMW dealer who sold me the car I think this has been all Jag services.
My JTIS should arrive today but I'll be too busy to do much more on this issue before it goes into the dealer.
Bob S.
Bob S.
It doesn't have to be post-MAF (but probably is) as even K&N filters or damaged air boxes are well-known to cause problems.
If they picked up lean codes during PPI, it did not get a clean bill of health. If it had the fuel trims you posted, it should not have had a clean bill of health because it was not healthy!
Well it did. But I don't have any readout from their inspection. They told me the codes had happend some time ago. There weren't any dates on the reader I was using yesterday. Does Jag keep a date/timestamp on this stuff?????
How does an air filter box problem or a K&N filter cause this? Are there sensors in the air filter box as well?
Bob S.
Bob S.
You mean: does the jag dealer or any other place keep data. Up to them. I'm 3000 miles away and don't know ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Looks to me the codes were there so there was no clean bill of health. Fuel trims like that also says no clean bill of health.
No idea, but it's so well known that I wouldn't get into why or how. (Turbulence maybe, but as I say I couldn't care less I just want my engine running properly.) You'll see avos has made comments and he's not the only one.
No, I meant date/timestamps in the ECU's datalog. How else could he say they were "old"?
You and I may now say that's not a clean bill of health but that's what the Jag dealer called it. Otherwise, I'd have had it resolved at the seller's expense. It's also not the only thing they missed.
Thanks again everyone for the input.
There's provision for something along those lines in OBD, but I don't think the S-Type's software supports it. Mine appears not to, but for all I know your newer car has different software ("calibration").
Ask them to substantiate their claim about the alleged oldness of the codes. I bet you find they can't!
If you tackled them about the air leak, showing their report implied it, they'd be in a pickle.
Well I checked for a loose hose clamp and neither of them moves at all. That big elbow piece is rather stiff plastic and not a nice rubber piece like on some of my other cars. I did notice that the center piece between the two intercoolers that is attached to the elbow wiggles around a bit.
Is that normal?
I'll let Jag sort this one out.
Bob S.
Is that normal?
Bob S.
Absolutely! Thanks very much.
Have a look folks. Good stuff there.
I'll be sure to print off a copy and give it to the tech tomorrow.
That should set things off on a good note.![Icon Bowrofl](https://www.jaguarforums.com/forum/images/smilies/icon_bowrofl.gif)
Bob S.
Bob S.
This might help http://www.gusglikas.com/AutoRepairTroubleShooting.htm
Is that normal?
Bob S.
Is that normal?
Bob S.
Well I dropped it off this morning and I wanted to talk with the mechanic and see if I could slip in a few points from the nice diagnostic piece provided by GUS but it's way too formal a place. Wouldn't you know it, I couldn't get it to thow a code again on my 10 mile trip over there. I did give the stuff I jotted down (earlier in this thread) that I got from the Autozone reader.
I got a loaner though it wasn't a Jag R car... A Chrysler 300-Ashtray model. They have a deal setup with Enterprise Rent A Car for $5 a day. I'm just glad they offer it.
Bob S.
Bob S.
So they looked for a vacuum leak and couldn't find anything so we're going to try a new MAF and see over the next few days and see if that fixes things up. A new air filter is going in as well. I imagine it's 5 years old.
I did discuss the center piece/plenum above the supercharger seeming to move around a bit and he said it has a thick rubber mounting gasket and that this is intentional?
The plastic elbow hose and air filter box certainly seem very stiff so maybe that's Jaguar's idea for allowing flexibility for engine movement?
Bob S.
Bob S.
