Got in the revised double ribbed pulley parts...Appears it has two options?
Uploaded with ImageShack.us
Based on the TSB for squeak belts, I bought the six parts it recommends...After looking at the parts ($362 total) I noticed something didn't add up...So I did more research and discover that it's two different sides, the supercharger side and the FEAD side...A mechanic has confirmed on my car the squeal was coming from the Supercharger side tensioner. According to below, I only need four parts...Any insights? Has anyone done this before? Once I get this done, it should really go in the FAQ because the original TSB wasn't very detailed...
REPAIR PROCEDURE
REPLACE FRONT END ACCESSORY DRIVE AND / OR SUPERCHARGER DRIVE BELT SYSTEM
NOTE:
Global Technical Reference (GTR) lookup sequence is as follows: GTR Home > NAS > Model > Service Information > Model Year > Workshop Manuals > 3: Powertrain > 303: Engine > 303-05 / 303-05A: Accessory Drive - 4.2L
1. If Normally Aspirated, refer to Workshop Manual (GTR) section 303-05 / 303-05A (12.93.06) and install a new flanged idler pulley (C2C 37064) and FEAD belt (C2C 37063).
2. If Supercharged, identify if the Front End Auxiliary Drive or Supercharger drive system is making the noise.
^ If FEAD system is noisy, refer to Workshop Manual (GTR) section 303-05 / 303-05A (12.93.06) and install a new flanged idler pulley (C2C 37064) and FEAD belt (C2C 37063).
^ If Supercharger drive system is noisy, refer to Workshop Manual (GTR) section 303-05 / 303-05A (18.91.38) and install a new grooved idler pulley (C2S 46862), tensioner (C2C 37057), pulley bracket (C2C 37056), and drive belt (C2C 37055).
The following 2 users liked this post by Jochem00:
Bacardi 151 (10-07-2011),
bfsgross (10-07-2011)
Hey Barcardi151, maybe my thread I made will help you out because I had the same problem....
https://www.jaguarforums.com/forum/s...ed-also-61644/
Hope it helps bro....
