Got an S-Type R
Agreed
That's all. Didn't mean to dis the STR. Love the STR.
The -R makes no additional HP of note at low engine speeds as compared to a non-R. It's lack of quality snow tires and a heavy right foot that causes most problems.
Sorry for the delay in my response but each outlet has one four inch tip. I still actually haven't picked the car up because I had to wait for the dealer to get four new tires to install on it and it has been snowing so I elected not to pick it up in the inclement weather. I'll know more on Monday.
#30
That would be correct. Remus does/did make a Romulus exhaust kit for the S-Type R. IIRC it was prohibitively (ridiculously) expensive, considering it was basically mufflers with tips at a cat-back system price. I don't think that they sold too many of those, but i always liked the tips & have been looking around for some that looked like theirs. No luck so far though.
#31
Hi guys,
I am loving my STR and I promise to get some photos on here in the near future. I seem to have a problem. On Saturday, I changed the air filter and I forgot to reconnect the vacuum hose that connects the plastic air intake elbow to the valve cover. I got a "restricted performance" message and a CEL. After reconnecting the hose, the message went away but the light stayed on. I disconnected the battery for about an hour and a half and that did not get rid of it. Will this go away in due course or do I have to get the code cleared?
I also noticed that the belt that turns the supercharger's pulley looks as if it is upside down; its ribs are visable atop the pulley. I am unsure if this is incorrect because it seems to sync up with the ribs of a tensioner pulley below. Is this okay?
Matt
Matt
#32
Hi guys,
Matt
Matt
THe CEL light will go away after a few drives once the computer sees that everything is now okay give it a few cycles and you should be good to go!
As for the belt, I believe that is the correct direction if memory serves me correctly, I will check mine later today to validate but you should be G2G!
Cheers!
#33
Hi guys,
Matt
Matt
You have the revised pulley system that is grooved on both sides of the belt. FYI the only replacement belts are Jaguar belts.
#34
#38
A "hard" reset is just a way of speeding up what disconnection will achieve if left off for a short while. You can visualise it as the car's modules being a leaking bucket constantly topped up by the battery. Disconnect and wait lets the bucket empty. Hard reset is like tipping the bucket over.
3jagfamily
10-01-2015 01:49 AM
