Handset in use!
Adding Bluetooth
I just got off the phone w/ JPAM and they wanted 187.50 for the bluetooth module part #C2S49706, but told me that I would also need another interface part #C2C34515 which was $511.89. I was thinking from reading all the info on the forum that if you already had the phone wired into your car that you would only need the bluetooth module. Can anyone confirm that both items are needed?
Maybe check the module in the trunk and see what part number it is.
Not stupid at all. Took me a while to get a grip on the "module" layout of the electronics. The short answer is yes. The "but" is, I guess based on the other things I've read that it depends on what number phone module is mounted in the trunk area. When you have the hard wired phone, it plugs into the phone module which is networked with the stereo unit. In order to have bluetooth, you replace the handset cradle and cable with a plug in bluetooth module. That should be it.
Yaoi-Wiccan
06-26-2013 08:59 PM
reacz
09-20-2012 11:16 AM
