hard shift from 1st to 2nd
You need to get your tranny reflashed. Mine had the same problem when it was in "normal" mode shifting from 1 to 2. In sport mode it shifted smoothly through all gears.
But I also got it reflashed because it was doing the lurch.
Since they reflashed, *knock on wood*, it has been as close to perfect as it can get. Smooth shifts and no more lurch.
It's worth the $$$.
It's worth the $$$.
Got my car back this week after dropping it off for other issues. They did call back about the TCM and ECM as they said they would. Apparently, they've had some changes in management and nobody left any notes. Now they're telling me the reprogramming is considered an "upgrade" and is not covered under warranty. But they also told me I have the latest version of the firmware.
The issue didn't seem to come up when in sport mode until recently this past week.
Had the exact same symptoms (harsh 1-2nd shift everything else OK) on my wifes 2002 STR. Had the ECU re-flash and seems to have made no difference
cost 100GBP to have done and i feel its been chucked down the pan. Was told to drive carefully for 200miles and not use kickdown, but really do not see how this is going to improve things!!!
Very frustrating and do not want to blow another 100GBP on having it done again for no result!!!!
![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
Guest
Posts: n/a
I just bought a 03 STR with 42K on it. Mine is doing the same Very hard Shift from 1st to 2nd. Could it be from driving it hard and the computer trying to learn your habits? I mean it is so hard of a shift I am embarrassed with passengers.
It didnt seem to do it prior to my race home with it and the showing off to family with a couple burn outs....
any ideas?
any ideas?
any ideas?
any ideas?
That should fix your issue.
ahunt4
09-19-2015 06:46 AM
